Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Show only
Search instead for
and get: 00:00:00.19 Initializing media cache C:/Users /katisss/AppData/Local/Temp/toxik/mediacache/store/32. 00:00:00.78 Memory option is set too low (422 MB). Will be increased to 512 MB. 00:00:00.79 Allocating 512 MB of memory for t he frame buffer cache (maximum is 1259 MB). 00:00:03.36 Error while loading plugin: C:/Pr ogram Files/Autodesk/Composite 2012/plugins/libDLwiretap.dlformat : Can't open d ynamic library 'C:/Program Files/Autodesk/Composite 2012/plugins/libDLwiretap.dl format': Das angegebene Modul wurde nicht gefunden. .. Plugin ignored. 00:00:03.39 Error while attempting to load pl ugin 'C:/Program Files/Autodesk/Composite 2012/plugins/libDLwiretap.dlformat': Can't open dynamic library 'C:/Program Files/Autodesk/Composite 2012/plugins/lib DLwiretap.dlformat': Das angegebene Modul wurde nicht gefunden. . Plugin ignored. 00:00:09.64 The following error occured while rendering: Assertion 'PiProjectSettings::isInitialized()' failed.
When i try to run from composite (send to backburner) windows i get: background task failed: Rendering ... Details: Return value 6.
what are your specs on your computer? what is your os? -it seems, you are running the 32bit version of composite. where is your mediacache located and have you set it to full read/write rights? ...
