Has the switch matchbox been removed? I can't find it on this intallation (2015)
Is there an alternitive?
Many thanks
Solved by fred.warren. Go to Solution.
Solved by myeffigy. Go to Solution.
You are right, it seems to be missing.
You can take the glsl files from 2012 and drop it into the matchbox directory. When accessing matchbox in cfx, you will have to select the dropdown menu for glsl. Currently it is set to matchbox as default. Then you can see the older glsl copied from an earlier version.
Cheers,
Mark
The funtionality has been integrated into the MUX node. You can now find a "Input Switcher" category at the bottom left of the MUX interface.
fred
Marvolus, thanks guys.
