Anybody know what is the expressions for negative scaling in action?
I know stabilzer node can do invert stabilizer using 2 axis
But i need the math operation for the axis negate scaling.
since action scaling value is 100.
thanks
elv
Solved by imag4media. Go to Solution.
Not sure if this is what you need but isn't it just -(axis.scaling) where axis is the name of your axis? This is then feed into another Axis node for inverting? SO you can copy the Scaling values in Axis1 and then link expression them in to Axis2 and then just negate with -(axis1.scaling)
Hmm. If you are looking to negate the scale of a track, back to it's original size it's a different answer.
If you put an Offset axis below Trk, and you want it to offset correctly at a frame other than 1, perhaps 99 for example, then these are the expressions you want to use:
Offset:
position: eval(Trk.position, 99) * -1
rotation.z: eval(Trk.rotation.z, 99) * -1
scaling: 10000/ eval(Trk.scaling, 99)
center: eval(Trk.position, 99)
Not sure if this was what you were looking for, but I use it all the time. This way if you change the track, it all updates automatically.
Of course this is all unnecessary if on 2014 or 2015 since there is a button on the axis that does this now.
Hope it helps.
Cheers-
Andy D.
Thanks guys...
this is very useful.
I'm doing some warphing with bicubic.
since bicubic is not trackable.... so sad.
But with this little expression now I can track my bicubic surface to my destination warp layer.
Using front source node with invert tracking data from it.
once again thank guys, now is very easy warphing some moving object in the action.
