txutil.exe clearcache
Experienced the same issue with Composite 2014; crash on foreground render and random render success on background.
In the interest of time, I uninstalled Composite 2014, restarted the system, ensure that no references to Composite appeared in the file system (Win 7 64-bit) and registry. Cleared out the user and system TEMP folder and reinstalled the latest version from the Autodesk Apps Exchange portal (http://apps.exchange.autodesk.com/3DSMAX/en/List/Search?facet=__category%3a%3aRendering).
According to the Help > About (Version 9.0-909216) and Add/Remove Programs (Version 16.0.0.0). Was able to pull off renders on every single composition that was crashing before.
... while I was at it, I did the same procedure for MatchMover since that's now a free component as well.
Cheers,
Ok so his is an old thread but here is a solution to many reasons composite will crash
So if your composite crashes as soon as you click render, like instantly after that click, its most likely a pathway error,
something is not being sent to the right place.
I would suggest this method to ensure that this doesnt happen:
First check that your system preferences are correct:
EDIT>SYSTEM PREFERENCES
check that PATH is pointing to a toxik.ini file, if not, you have to create a toxik.ini to your local drive somewhere.
Then set the preferences (highlighted in red botom right, the reel)
It will open this window, make sure you set the RENDER FOLDER and FILE NAME through the path links highlighted in red on the right.
As you can see in the image, the file name only has the filename, this will definitely crash like this
This Is correct
Once this is done go through and set your composition (highlighted in red), also ive never really needed to change any of the other settings,
Now go FILE>NEW and make sure you set the pathway to the same place as everything else
Ok so now you have done that, so far all the pathways are correct, but it will probably still crash because the node it creates doesnt remember the render path.
Click on the output node you just created and click on the RENDER tab
You will notice the file name just has the file name, this need the path as well as the filename
As before click on the small box highlighted in red, set the pathway for the same place as you did in the preferences at the start and make sure the name is exactly the same, this is very important that the render node matches the preferences settings,
like this:
Now this should prevent you composite scene from crashing on render
But If you are still having problems, its possible it could be your cache or your computer just might not have the power, RAM is essential but you also need a fairly decent computer.
Hope that helps
Josh
