Hi I'm running smoke mac 2013 Ext1 with AJA KONA3, during a I/O test to HDSR deck I noticed a color shift when capturing footage into the smoke. The amount of shift varies when I change to various compression settings in the "Cache and Renders" tab in project settings (uncompressed, 422, 422HQ, 444, etc) and do a re-capture of the same source. The source being captured is standard smpte color bars, visually the shift is barely visible but I can see the shift when I look at the vector scope. There is quite a difference in shift between setting the project to 422HQ and uncompressed when capturing the same footage.
I'm wondering if anyone else is experiencing the same thing? Although the shift may not be significant, it's frustrating to not be able to bring in something and output it EXACTLY the same as what it was on tape. I've worked with smoke on linux in the past and never had this issue, is this a MAC only thing?
-Jay
There is more shift with uncompresed setting. Turning on headroom shifts gamma, the shift I'm seeing is more of a saturation shift on scope.
-jay
