Stitcher General Discussion (Read Only)
General discussion of Autodesk Stitcher-related topics, questions, or comments
Windows Vista and Fisheye Images
3 REPLIES 3
266 Views, 3 Replies
Hey Folks,
Is there a problem with Stitcher on a Windows Vista OS that won't allow you to see the panorama in the viewing window when working with full frame fish eye images? The software is reading the EXIF data normally, but the view screen is blank and the small preview window is not visible either. It will indeed render and then appears when I open it up as a panorama. Also, I can't drag a single image thumbnail (which all are visible) into the viewing window. Nothing happens. I've tried setting the camera calibration and disengaging the "reading of the EXIF data," but to no avail.
The same Stitcher 5.7 software works perfectly on my desktop Windows XP OS.
I downloaded the trial 2009 version, but it's the same thing.
Any suggestions?
Thanks in advance,
Jon Eady
Denver CO
USA
3 REPLIES 3
What lens type are you setting? You should set it to Fisheye Circular.
I'm using a Nikkor 10.5 DX Full Frame fisheye.
I have a similar problem exporting cubic qtvr, in that, the .mov file is not viewable in quicktime - not sure if it a windows vista 64 bit issue? Let me know if that too is a problem?
thanks, rob
