I know a lot of users are seeing the post to the apps exchange as the death of Composite, but I have reached out to Chris Vienneau about this and asked where a user like myself could send feature requests. With that I would like to start a thread to find out what others would realistically like to see in Composite in the future. By realistic I mean not feature-to-feature competition with AE, Nuke, or Digital Fusion, but where are the little things here and there that could really help to improve the experience? Also, what are the features that you find lacking in the other packages?
I plan to pass this thread along with my own list in a week, or so, to see what Autodesk can do with Composite.
-Eric
Thanks Eric for being so proactive with this! I have not used Composite long enough to give some valuable feedback. There are many on these forums who definitely have made some great requests though.
I really do hope that the free release of the software makes some noise and helps build a positive future for the once dead app.
I never really commited to investing time in learning the software because there was no future and a very small userbase. But with the app now being freely available to all (and not forever lost like combustion), both those drawbacks can be changed without the help of Autodesk. But if there was the help of Autodesk, the future of composite would be much, much more interesting!
The first request that comes to mind is the Composite net-rendering hassle that I dealt with recently (workaround thanks to Eric!).
It ought to be possible to have slaves net-render via BB even if some slaves have their Composite install on drives other than C, such as D or E, etc.
MAX has no problem net-rendering if some slaves installs are on C and others on D or E, etc. Deadline lets you specify all possible paths to the render executable such as C:\etc., and D:\etc. and at render time it searches those paths for the exe. Seems like there should be a way Composite can deal with differing install locations and still net-render on all slaves.
Thanks!
Hehe... that was just the first request that came to my mind... not necessarily the first priority. Stability is definitely the first priority as I can make Composite crash simply by mis-entering the syntax for a path to files. This happened repeatedly as I was trying to setup paths for footage or rendered frames, etc.
But now that Composite is officially free/abandoned, I would be surprised if any real effort was put into it in the future. If they gave the code away free, perhaps someone could improve upon it. But that then might threaten other AD products?
Anyway, I hope there is improvement in the future.
Thanks!
I don't think that I push it hard at all and I take it out quite often. Hard to say what does it as well as it will always be something different. Usually auto saves and I can keep going but it is a show stopper when it comes to real productions on real dead lines. I was just talking to a shop last month that said they tried to use it and it worked for everything they were doing except it wasn't stable. So they moved to Nuke.
- Stability
- Speed reading files over the Network (takes ages to display image sequences)
- Quick tool search like you have in Nuke with the tab button.
- Last file opened in the File list
- Drag and drop files and folders
- Stability
These would be great!
Femi
Steve, the UI is not some evil corporate theme, it is made to comply with a SMPTE standard. It's supposed ot offer a neutral background that doesn't interfere with your perception of the image you are working on. I have found over the years that it definitely cuts down on eye strain (56 years old and I still don't need glasses).
You must work in a very bright room, which is not good for your work. Again, there is a SMPTE standard that covers this. You should check it out. These day pretty much all design software has a similar UI. How do you get by with Photoshop or After Effects?
So let me get this straight, you don't want companies who have gone to a lot of trouble to comply with a standard written for the sole purpose of allowing you to do your job better but you're happy to allow other companies, who just randomly decided on some colours that looked pretty and worked acceptably well with spreadsheets and word processors 20 years ago, to decide your preferences for the rest of your life. That's weird, dude.
Mete, every time I install MAX I spend half-an-hour customising it to try and get it close to the SMPTE standard, as well as getting my quads just right. One day I'll get smart enough to save the set-up on a USB drive so I can just load it. One day. Meanwhile, you shoudl re-evaluate the way you work, SMPTE don't do this stuff for fun, they are trying to help.
