tks.
Today i made a few testes and:
1 - only DPX stay pending ( strange ? ), if i import a H264 everything is ok (you can see it in attachment). Perhaps because my shared folder in server (framestore) is the same place that i have DPX ? ( i have one folder created by smoke, and another one that the grading guy use to sende me DPXs.
2 - I can export DPXs
My Log file today:
2013/10/07 10:33:56 INF <AdapterInfo>
2013/10/07 10:33:56 INF <Name>Command Line Tool</Name>
2013/10/07 10:33:56 INF <Version>300</Version>
2013/10/07 10:33:56 INF <Description>Command Job Adapter v2013.1</Description>
2013/10/07 10:33:56 INF </AdapterInfo>
2013/10/07 10:33:56 INF <AdapterInfo><Name>MediaConverter_2013.2.0</Name><Version>410</Version><Description>Autodesk Media Converter 2013.2.0</Description><Private><Info><HostUUID>06DBD96A-D2F4-440B-ACDF-062B1DE91DEE</HostUUID></Info></Private></AdapterInfo>
2013/10/07 10:33:57 INF <AdapterInfo><Name>mio_3</Name><Version>-1</Version><Description>MIO File Import 2013.2.0 (build 2043)</Description></AdapterInfo>
2013/10/07 10:33:57 INF <Name>Command Line Tool</Name>
2013/10/07 10:33:57 INF <Version>400</Version>
2013/10/07 10:33:57 INF <Description>Command Job Adapter v2013.1 with user rights</Description>
2013/10/07 10:33:57 INF </AdapterInfo>
2013/10/07 10:33:57 INF [notice] 377528320 CoThreadPthread.C:200 10/07/13:10:33:57.165 Registered thread 'CoNetworkMonitor Thread' [ 4672495616 ]
2013/10/07 10:33:57 INF <AdapterInfo><Name>Wire</Name><Version>-1</Version><Description>Stone+Wire Background Wire 2013.2.0 </Description><Private><Info><HostUUID>06DBD96A-D2F4-440B-ACDF-062B1DE91DEE</HostUUID></Info></Private></AdapterInfo>
2013/10/07 10:33:57 INF Starting backburner Server
2013/10/07 10:33:57 INF Loading plugin: Command Job Adapter v2013.1 from Backburner Adapter Plugin
2013/10/07 10:33:57 INF Loading plugin: Autodesk Media Converter 2013.2.0 from Backburner Adapter Plugin
2013/10/07 10:33:57 INF Loading plugin: MIO File Import 2013.2.0 (build 2043) from Backburner Adapter Plugin
2013/10/07 10:33:57 INF Loading plugin: Command Job Adapter v2013.1 with user rights from Backburner Adapter Plugin
2013/10/07 10:33:57 INF Loading plugin: Stone+Wire Background Wire 2013.2.0 from Backburner Adapter Plugin
2013/10/07 10:33:57 INF <Version>300</Version>
2013/10/07 10:33:57 INF <Description>Command Job Adapter v2013.1</Description>
2013/10/07 10:33:57 INF <AdapterInfo><Name>MediaConverter_2013.2.0</Name><Version>410</Version><Description>Autodesk Media Converter 2013.2.0</Description><Private><Info><HostUUID>06DBD96A-D2F4-440B-ACDF-062B1DE91DEE</HostUUID></Info></Private></AdapterInfo>
2013/10/07 10:33:57 INF [notice] 377528320 CoThreadPthread.C:200 10/07/13:10:33:57.681 Registered thread 'CoNetworkMonitor Thread' [ 4672495616 ]
2013/10/07 10:34:10 INF Registration to 192.168.151.10 accepted
2013/10/07 10:55:59 INF Receiving new job from 192.168.151.10
2013/10/07 10:55:59 INF Job 'Cache - AAC (10.55.59)' received and ready
2013/10/07 10:55:59 INF Launching 'Wire'
2013/10/07 10:56:00 INF New task assigned: 1
2013/10/07 10:56:02 INF [notice] 377528320 CoThreadPthread.C:200 10/07/13:10:56:00.100 Registered thread 'CoNetworkMonitor Thread' [ 4672495616 ]
2013/10/07 10:56:02 INF [notice] 2001191296 swClient.C:311 10/07/13:10:56:00.104 Using Stone+Wire API 2013.2.0 [2043] (64 bits) PID:927.
2013/10/07 10:56:02 INF [notice] 385368064 CoThreadPthread.C:200 10/07/13:10:56:00.108 Registered thread 'S+W Net Input' [ 4680335360 ]
2013/10/07 10:56:02 INF [notice] 403705856 CoThreadPthread.C:200 10/07/13:10:56:00.108 Registered thread 'S+W Net Output' [ 4698673152 ]
2013/10/07 10:56:02 INF [notice] 404766720 CoThreadPthread.C:200 10/07/13:10:56:00.108 Registered thread 'S+W Net Watchdog' [ 4699734016 ]
2013/10/07 10:56:02 INF [notice] 405827584 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Audio Processor' [ 4700794880 ]
2013/10/07 10:56:02 INF [notice] 406888448 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Audio Processor' [ 4701855744 ]
2013/10/07 10:56:02 INF [notice] 407949312 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Image Converter' [ 4702916608 ]
2013/10/07 10:56:02 INF [notice] 409010176 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4703977472 ]
2013/10/07 10:56:02 INF [notice] 410071040 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4705038336 ]
2013/10/07 10:56:02 INF [notice] 420483072 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4715450368 ]
2013/10/07 10:56:02 INF [notice] 421543936 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4716511232 ]
2013/10/07 10:56:02 INF [notice] 422604800 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4717572096 ]
2013/10/07 10:56:02 INF [notice] 423665664 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4718632960 ]
2013/10/07 10:56:02 INF [notice] 424726528 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4719693824 ]
2013/10/07 10:56:02 INF [notice] 425787392 CoThreadPthread.C:200 10/07/13:10:56:00.110 Registered thread 'S+W Pipeline' [ 4720754688 ]
2013/10/07 10:56:02 INF [notice] 435159040 CoThreadPthread.C:200 10/07/13:10:56:00.133 Registered thread 'S+W Gateway connection timer monitor' [ 4730126336 ]
2013/10/07 10:56:02 ERR Task error: [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:56:01.276
[error] 2001191296 swBIOAdapter.C:454 10/07/13:10:56:02.333 Cannot process tasks 0... in /var/tmp/WireJob/SubJob0
Caller passed bad parameter on processing S+W server
2013/10/07 10:56:02 ERR [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:56:01.276
2013/10/07 10:56:02 INF Application is down
2013/10/07 10:56:33 INF Receiving new job from 192.168.151.10
2013/10/07 10:56:34 INF Job 'Cache - AAC (10.55.59)' received and ready
2013/10/07 10:56:34 INF Launching 'Wire'
2013/10/07 10:56:34 INF New task assigned: 1
2013/10/07 10:56:36 INF [notice] 377528320 CoThreadPthread.C:200 10/07/13:10:56:34.141 Registered thread 'CoNetworkMonitor Thread' [ 4672495616 ]
2013/10/07 10:56:36 INF [notice] 2001191296 swClient.C:311 10/07/13:10:56:34.142 Using Stone+Wire API 2013.2.0 [2043] (64 bits) PID:961.
2013/10/07 10:56:36 INF [notice] 384319488 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Net Input' [ 4679286784 ]
2013/10/07 10:56:36 INF [notice] 385380352 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Net Output' [ 4680347648 ]
2013/10/07 10:56:36 INF [notice] 412094464 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Net Watchdog' [ 4707061760 ]
2013/10/07 10:56:36 INF [notice] 415240192 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Audio Processor' [ 4710207488 ]
2013/10/07 10:56:36 INF [notice] 417361920 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Image Converter' [ 4712329216 ]
2013/10/07 10:56:36 INF [notice] 418422784 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4713390080 ]
2013/10/07 10:56:36 INF [notice] 416301056 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Audio Processor' [ 4711268352 ]
2013/10/07 10:56:36 INF [notice] 419483648 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4714450944 ]
2013/10/07 10:56:36 INF [notice] 420544512 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4715511808 ]
2013/10/07 10:56:36 INF [notice] 421605376 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4716572672 ]
2013/10/07 10:56:36 INF [notice] 422666240 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4717633536 ]
2013/10/07 10:56:36 INF [notice] 423727104 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4718694400 ]
2013/10/07 10:56:36 INF [notice] 424787968 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4719755264 ]
2013/10/07 10:56:36 INF [notice] 425848832 CoThreadPthread.C:200 10/07/13:10:56:34.144 Registered thread 'S+W Pipeline' [ 4720816128 ]
2013/10/07 10:56:36 INF [notice] 435220480 CoThreadPthread.C:200 10/07/13:10:56:34.159 Registered thread 'S+W Gateway connection timer monitor' [ 4730187776 ]
2013/10/07 10:56:36 ERR Task error: [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:56:35.149
[error] 2001191296 swBIOAdapter.C:454 10/07/13:10:56:36.204 Cannot process tasks 0... in /var/tmp/WireJob/SubJob0
2013/10/07 10:56:36 ERR [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:56:35.149
2013/10/07 10:56:36 INF Application is down
2013/10/07 10:57:07 INF Receiving new job from 192.168.151.10
2013/10/07 10:57:07 INF Job 'Cache - AAC (10.55.59)' received and ready
2013/10/07 10:57:07 INF Launching 'Wire'
2013/10/07 10:57:07 INF New task assigned: 1
2013/10/07 10:57:10 INF [notice] 377528320 CoThreadPthread.C:200 10/07/13:10:57:07.986 Registered thread 'CoNetworkMonitor Thread' [ 4672495616 ]
2013/10/07 10:57:10 INF [notice] 2001191296 swClient.C:311 10/07/13:10:57:07.987 Using Stone+Wire API 2013.2.0 [2043] (64 bits) PID:982.
2013/10/07 10:57:10 INF [notice] 383270912 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Net Input' [ 4678238208 ]
2013/10/07 10:57:10 INF [notice] 385392640 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Net Watchdog' [ 4680359936 ]
2013/10/07 10:57:10 INF [notice] 384331776 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Net Output' [ 4679299072 ]
2013/10/07 10:57:10 INF [notice] 413143040 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Audio Processor' [ 4708110336 ]
2013/10/07 10:57:10 INF [notice] 414203904 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Audio Processor' [ 4709171200 ]
2013/10/07 10:57:10 INF [notice] 415264768 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Image Converter' [ 4710232064 ]
2013/10/07 10:57:10 INF [notice] 416325632 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4711292928 ]
2013/10/07 10:57:10 INF [notice] 417386496 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4712353792 ]
2013/10/07 10:57:10 INF [notice] 418447360 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4713414656 ]
2013/10/07 10:57:10 INF [notice] 419508224 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4714475520 ]
2013/10/07 10:57:10 INF [notice] 420569088 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4715536384 ]
2013/10/07 10:57:10 INF [notice] 421629952 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4716597248 ]
2013/10/07 10:57:10 INF [notice] 422690816 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4717658112 ]
2013/10/07 10:57:10 INF [notice] 423751680 CoThreadPthread.C:200 10/07/13:10:57:07.988 Registered thread 'S+W Pipeline' [ 4718718976 ]
2013/10/07 10:57:10 INF [notice] 435085312 CoThreadPthread.C:200 10/07/13:10:57:08.004 Registered thread 'S+W Gateway connection timer monitor' [ 4730052608 ]
2013/10/07 10:57:10 ERR Task error: [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:57:08.993
[error] 2001191296 swBIOAdapter.C:454 10/07/13:10:57:10.044 Cannot process tasks 0... in /var/tmp/WireJob/SubJob0
2013/10/07 10:57:10 ERR [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:57:08.993
2013/10/07 10:57:10 INF Application is down
2013/10/07 10:57:41 INF Receiving new job from 192.168.151.10
2013/10/07 10:57:41 INF Job 'Cache - AAC (10.55.59)' received and ready
2013/10/07 10:57:41 INF Launching 'Wire'
2013/10/07 10:57:41 INF New task assigned: 1
2013/10/07 10:57:43 INF [notice] 377528320 CoThreadPthread.C:200 10/07/13:10:57:41.829 Registered thread 'CoNetworkMonitor Thread' [ 4672495616 ]
2013/10/07 10:57:43 INF [notice] 2001191296 swClient.C:311 10/07/13:10:57:41.830 Using Stone+Wire API 2013.2.0 [2043] (64 bits) PID:998.
2013/10/07 10:57:43 INF [notice] 384831488 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Net Input' [ 4679798784 ]
2013/10/07 10:57:43 INF [notice] 403705856 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Net Output' [ 4698673152 ]
2013/10/07 10:57:43 INF [notice] 404766720 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Net Watchdog' [ 4699734016 ]
2013/10/07 10:57:43 INF [notice] 405827584 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Audio Processor' [ 4700794880 ]
2013/10/07 10:57:43 INF [notice] 407949312 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Image Converter' [ 4702916608 ]
2013/10/07 10:57:43 INF [notice] 406888448 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Audio Processor' [ 4701855744 ]
2013/10/07 10:57:43 INF [notice] 409010176 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4703977472 ]
2013/10/07 10:57:43 INF [notice] 410071040 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4705038336 ]
2013/10/07 10:57:43 INF [notice] 411131904 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4706099200 ]
2013/10/07 10:57:43 INF [notice] 412192768 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4707160064 ]
2013/10/07 10:57:43 INF [notice] 413253632 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4708220928 ]
2013/10/07 10:57:43 INF [notice] 414314496 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4709281792 ]
2013/10/07 10:57:43 INF [notice] 415375360 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4710342656 ]
2013/10/07 10:57:43 INF [notice] 416436224 CoThreadPthread.C:200 10/07/13:10:57:41.831 Registered thread 'S+W Pipeline' [ 4711403520 ]
2013/10/07 10:57:43 INF [notice] 425807872 CoThreadPthread.C:200 10/07/13:10:57:41.847 Registered thread 'S+W Gateway connection timer monitor' [ 4720775168 ]
2013/10/07 10:57:43 ERR Task error: [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:57:42.835
[error] 2001191296 swBIOAdapter.C:454 10/07/13:10:57:43.888 Cannot process tasks 0... in /var/tmp/WireJob/SubJob0
2013/10/07 10:57:43 ERR [error] 2001191296 swBIOSubJobServer.C:385 10/07/13:10:57:42.835
2013/10/07 10:57:43 INF Application is down
