Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
General Discussion
Distinguished Contributor
DarthWayne_1
Troubleshooting and Bugs
704 Views, 357 Replies
10-23-2008 08:57 PM
Notice:
I've been asked to inform you all that in future all bugs and suspected bugs are to be posted in this thread as some are getting pushed onto page 2 etc and may get missed. This will make it easier to track and help with all bugs users may experience or be unsure about, and so that no one fails to get an answer about a bug, problem or suspected bug.
Please clearly state your bug or problem , your hardware setup and OS and any relevant details as this will help you to get any problems dealt with faster.
Wayne...
www.MudboxHub.com Independant Mudbox User Forum
www.DashDotSlash.net - personal site
Please use plain text.
Active Member
neutrondog
Re: Troubleshooting and Bugs
10-23-2008 09:14 PM in reply to: DarthWayne_1
I'm pretty sure this isn't a bug but it's driving me crazy and I need to know if it's a software, computer or cockpit issue.
I created a mesh in XSI and when I try to paint a bump map on it the brush strength behaves as if it is set to max but the same brush and settings paints just fine on a Mudbox 2009 created mesh. I've attached a screen shot showing the problem.
Does anyone have any idea what's going on or how to fix it or workaround it?
computer: HP AMD Athlon 64 X2 3GB RAM
OS : XP Pro
video card: NVidia 9800
Wacom Intuos 3
skycastleMud
10-23-2008 11:47 PM in reply to: DarthWayne_1
Did you assign a unique shader to each object? And change the bump strength perhaps for one material?
skycastleMud
10-23-2008 11:56 PM in reply to: DarthWayne_1
Could you tell us if you scaled the object or transformed it before painting?
Active Member
neutrondog
10-24-2008 12:19 AM in reply to: DarthWayne_1
Yes, the model was scaled. When I imported it into MB it came in so small compared to a MB head that I scaled it up from within Mudbox.
I just tried it again without scaling and the brush painting appears to behave, then I scaled it up in MB and the brush problem comes back.
I'll scale models before bringing them into MB, this is a workaround I can live with.
Active Contributor
dburdick_1
10-25-2008 02:29 PM in reply to: DarthWayne_1
Potential Bug: Painting does not cover all areas of mesh
Here's a link to the source MB scene file:
http://www.skinvue.net/Mudbox/MudPaintBug.zip
Active Contributor
dburdick_1
10-25-2008 04:08 PM in reply to: DarthWayne_1
Possible Bug: Tiling Stencils don't work in Paint Projection Mode
When using Projection Paint, tiling the stencil does not work. It only allows you paint over the single tile of the original stencil.
DarthWayne_1
10-25-2008 05:36 PM in reply to: DarthWayne_1
The problem was your UV's. They were simply too close to the edges of the tile (I always leave a 2-4pixel gap between each island and also the edges of the tile.) There were a couple of other minor UV problems as well but those were not the cause. Also your mesh is a bit tiny to be frank, So I've included a image to show the difference in scale between the default human base fro mudbox and yours. This has a very big effect on how mudbox operates...so scale it up a fair whack , export the obj back out and then reimport things again and this will solve the size issue. If you dont scale it up the sculpting brushes may well seem hyper sensitive and way too over blown.
Hope that helps.
Wayne...
10-25-2008 06:33 PM in reply to: DarthWayne_1
Hi there.
Here are a couple of bugs.
Selection won't work
Goes for all kinds, even select-all and is object-specific. The workaround I have found is to drop and then go up one subd level, or to add a new level. After doing so, selection will work fine again for that object. This happens very frequently. I can still sculpt those meshes, just not perform selections on them. I have a feeling it might be objects I don't modify in mudbox but are static subdivided parts of the scene like armor pieces and such.
"Unfreeze all" critical problem
XP32: I get an "An unknown error has occured..." message, and can continue working on the model
XP64: Unfreeze crashes mudbox like in the screenshot below.
EDIT: Invert freeze crashes on XP32, same as in the screenshot
This happens regardless of whether anything was frozen to start with. This doesn't happen when I load a clean scene with the mudbox head model.
Let me know where, and I'll send you a file that illustrates both problems.
System specs
XP32 SP 2 / XP64 SP2 (Recent install, very stable)
Intel Core 2 Duo E6600 2.4GHz
4GB
GF 8600GTS 256MB
New Member
Robin Brook
10-26-2008 12:23 PM in reply to: DarthWayne_1
If the Active brush stamp image file is removed, mudbox crashes on startup. not a major one but something you might want to look into nonetheless.
win xp 32
athlon x2 5200+
8800 gts 640mb
