Hi everyone!
A litle help for a litle issue.
I export a AAF sequence from avid with some tgas whit alpha imported with the classic method (not by AMA.
When i conform on smoke 2013, it appears the tga as a Nested Matte Container, but Smoke doesn't import the alpha channel and we must to fix it searching and importind the alpha channel of every tga one by one (and there are a lot!!!)
There is any solution for this problem?
Thank's!
P.S. I use avid media composer 5.5 and smoke advanced on linux 2013
Does it matter if you change the import setting in MediaHub to Include Alpha instead of Matte Container? Not even sure that's an option in Conform.
Hi Brian! It does not work well. When we open the nested effect, we appear twice the fill layer and not alpha channel's layer. We will continue investigating.
Thanks for your commment!
Enric
