Hi everyone,
i'm experiencing the exact same issue
- unable to export (Connection refused)
- takes forever to open a project
I don't know how this problem was solved on your side 1 year and a half ago but if you have get a chance, i could use your experience on solving this issue
Thanks a lot
Hi.
The cause of your issue might be quite different now, as I assume you're using a newer version of Smoke.
Sounds like there might be a network communication issue with Backburner and/or some project locks.
Can you please unzip and run the attached app and then send me over the zip file if places on your desktop?
The zip will contain Smoke logs and config files as well as info on your Mac's network settings.
Best regards,
Robert.
Hi Robert,
Thank you for your reply.
Sorry i didn't get back to you earlier, i was supposed to deliver revisions on that project and i managed to archive the main sequences and reload them in a new project which allowed me to make my changes and exports without any problem.
One week later this second project is behaving the same way so i guess its specific to the medias related to that project. Don't know.
Anyway, you'll find attached the logs you asked for, i lauched that second project (which took a while) then made changes on a sequence and attempted to export. It didn't work. I ran your log app right after.
Hope it helps to locate the problem
Thank you again for your reply and time,
Seif
