Hey there! I'm sure this is a simple solution, but I can't seem to find it myself.
In Smoke 2015, any changes I make to my project will not update until I release the mouse. For example, if I need to move an object around, adjust an effect, or anything else involving a slider, it will not show me the changes made until the mouse is release. This makes fine-tuning position and certain effect very annoying, since I keep having to release the mouse just to see what's happening, then repeat until I finally get it right. I know it's probably a basic solution, but I'm just learning Smoke and haven't gotten it down quite yet. Thank you!
Solved by BKM. Go to Solution.
I assume you are in Action or CFX and in 2 up view.
Hit the VIEW button on the right and look for an option towards the bottem center that says Update Selected and change it to Update all.
