Today I wasn't able to find the scale tool:
I used it like two weeks ago and now it just isn't there!
I have looked at the tutorials and it should be there. Am I doing something wrong?
Solved by zhanganchun. Go to Solution.
It is not yet integrated into parametric modeling- to see it you need to "Add Base Feature"
Currently Scale is available in two environments:
1 Don't capture design history - convert the model to be direct modeling.
2 Parametric “Create Base" environment.
Parametric Scale Body will be available in next release.
