Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
SP5 freezes with certain footage
1 REPLY 1
156 Views, 1 Reply
Hello
So my machine matches the SP5 specs and I can run the footage that comes with the SP5 tutorials when you download it from Autodesk but I cant run ANY of the footage I get from the FxPHD tuts.
I am running them from a G-Tech Raid via eSata. Once I try to play them Smoke just freezes. And its just Smoke with the spinning wheel bc all my other apps and internet will continue to work.
The footage is Pro res but Smoke says its 720p 10bit.
The SP5 tuts footage is in jpg format.
Here is there error log:
Jan 25 13:31:55 :
Jan 25 13:31:55 : ---------------------------------------------------------------------------
Jan 25 13:31:55 :
Jan 25 13:31:55 : Autodesk(R) Smoke(R) Version 2011.SP5 P3962
Jan 25 13:31:55 : Autodesk and Smoke are registered trademarks or trademarks of Autodesk, Inc., and/or its subsidiaries and/or affiliates in the USA and/or other countries. All other brand names, product names, or trademarks belong to their respective holders.
Jan 25 13:31:55 : Autodesk reserves the right to alter product offerings and specifications at any time without notice, and is not responsible for typographical or graphical errors that may appear in this document. (C) 2010 Autodesk, Inc.
Jan 25 13:31:55 :
Jan 25 13:31:55 : BUILD DATE : Tuesday December 7 2010 12:55 EST
Jan 25 13:31:55 : EXEC DATE : Tue Jan 25 13:31:55 2011 - (1295991115)
Jan 25 13:31:55 : CONFIG : /usr/discreet/smoke_2011.SP5/cfg/init.cfg
Jan 25 13:31:55 : POINTER : Trying wacom
Jan 25 13:31:55 : AUDIO : Core Audio
Jan 25 13:31:55 : Executing command: /bin/sh /usr/discreet/smoke_2011.SP5/bin/platforminfo
Jan 25 13:31:55 : MENU : /usr/discreet/smoke_2011.SP5/menu/default.menu
Jan 25 13:31:56 : POINTER : Initialising.
Jan 25 13:31:56 : POINTER : "wacom" not found
Jan 25 13:31:56 : POINTER : Initialising Mouse.
Jan 25 13:31:57 :
Jan 25 13:31:57 : Workstation: MacPro5,1
Jan 25 13:31:57 : CPU: 2 6-Core Intel Xeon @ 2.66 GHz, 12 cores
Jan 25 13:31:57 : RAM: 12 GB of RAM
Jan 25 13:31:57 : Graphics: ATI Radeon HD 5870 Driver:
Jan 25 13:31:57 : OS: Mac OS X 10.6.6 (10J567)
Jan 25 13:31:57 : Kernel: Darwin 10.6.0
Jan 25 13:31:57 :
Jan 25 13:31:57 : GRAPHICS : Supported depths: 8, 10, 12, 16fp bits
Jan 25 13:31:57 : AUDIO : Default directory: ~/audio
Jan 25 13:31:57 : AUDIO : Import-Export directory: ~/audio
Jan 25 13:31:58 : Tue Jan 25 13:31:58 Macintosh.local smoke <Error>: CGImageCreate: invalid image size: 0 x 0.
Jan 25 13:32:02 : VOLUMEMGT : Using 7 as root partition.
Jan 25 13:32:03 : VOLUMEMGT : Warning: Aborting future hardware disk health check
Jan 25 13:32:58 : IM: Off-the-spot input method opened.
Jan 25 13:33:05 : PRJMGT : Load Project, failed to switch to group
Jan 25 13:33:10 : PROJECT : Yet_another_test
Jan 25 13:33:10 : VOLUME : stonefs7
Jan 25 13:33:10 : USER : Albert
Jan 25 13:33:10 : CONFIG : /usr/discreet/project/Yet_another_test/cfg/Yet_another_test.cfg
Jan 25 13:33:10 : VIDEO: monitor refresh rate detected as: 59.875015
Jan 25 13:33:10 : VIDEO: non-standard monitor refresh rate (59.875015). Audio/Video playback may not be in sync.
Jan 25 13:33:11 : VOLUMEMGT : Mapping project "Yet_another_test":
Jan 25 13:33:11 : : mapping desktop "editing" ...
Jan 25 13:33:11 : : Cannot open /usr/discreet/clip/stonefs7/Yet_another_test/editing.000.desk: No such file or directory.
Jan 25 13:33:11 : VOLUMEMGT : Mapping done.
Jan 25 13:33:11 : PROCESSORS : 24 available
Jan 25 13:33:11 :
Jan 25 13:33:11 : VOLUMEMGT : Framestore integrity check not needed...skipped.
Jan 25 13:33:11 : MEMORY : Bytes available: 10895 MB
Jan 25 13:33:11 : MEMORY : Using 3000 MB (or 853 buffers of size 1280x720 @ 8-bit).
Jan 25 13:33:11 : MEMORY : Allocated 3000 MB at address 0x1b377c000 using memalign()
Jan 25 13:33:22 :
Jan 25 13:33:22 : EDL Module: Portions Copyright � 1991-1998 ALBA Editorial, Inc.,
Jan 25 13:33:22 : All Rights Reserved.
Jan 25 13:33:22 :
Jan 25 13:33:22 : MaxLibrarySize: 1 MB ==> 75 MB.
Jan 25 13:34:00 : NETWORK : Cannot create backup for the imported library state file.
Jan 25 13:36:39 : Application: smoke 2011.SP5 x86_64
Jan 25 13:36:39 : Pid: 481
Jan 25 13:36:40 : Uninitialising thread manager.
Jan 25 13:36:43 :
Any Ideas?
-Albert
1 REPLY 1
UPDATE!:
So I turned the FXPHD footage to h.264 and it works fine...So I guess I cant run 720p Pro Res or 10bit of an eSATA?
-Albert
