I'm in the middle of a comform with a bunch of layers and compositing and suddenly nothing in Smoke will play. I get a GREEN ARROW ICON when I hit the play button, but the play head does not move. I can scrub up and down the sequence but no play. I've tried restarting Smoke and a full shut down of the system and nothing seems to play, source material or timeline. Please help I'm on a deadline!
I would attach a log but I forgot which log to attach.
Here are my log files.
I created a new project and reconformed yesterday and it seemed ok. This morning I started up my project, created a composite and it started to flicker like it was skipping frames, then it would not play.
I noticed the project was setup as 60P. What are the sources and what format are you using for the framestore? Does it play if you disable audio? What version AJA drivers are you using?
Give support a call to check it out.
cheers
Jason
Hi Dennis.
Try also creating a new Smoke user and see if that makes any difference.
Robert.
