Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Projects Missing
10 REPLIES 10
Message 1 of 11
moreymichael
851 Views, 10 Replies
Projects Missing
I've been using Smoke 2015 on a second system as Trial for a week because I was having problems with my primary system (problem now solved). Completed a job, and 2 other jobs ongoing on this trial system. Today, when I launch Smoke, it shows no projects from that drive. The folders still exist in /usr/discreet/projects and the project.db shows the projects in the list. The simply don't show up in the startup window.
Yes, the media drive is connected, and it is still listed in the Smoke Setup Media Storage list. I haven't changed anything on this system since using it yesterday (albeit at a different location). And there are still 17 days remaining on the trial software.
Any ideas?
Cheers, Mike
Late 2013 MacPro, 10.9.5, 2.7 GHz 12-Core, 64GB ram, AMD D700, 1TB SSD
10 REPLIES 10
Message 2 of 11
theonlyandyt
in reply to: moreymichael
On the log in screen, make sure the "Host Computer" is set to your computer. Also make sure "Project" is set to All Versions.
That should do it.
MacBook Pro Retina, 2.7GHz Intel Core i7, 16GB RAM, Thunderbolt 2 R6
Message 3 of 11
moreymichael
in reply to: theonlyandyt
Thanks for the reply, TOAOT,
All of those settings are correct (on this system, there are no alternate options for those settings).
Cheers, Mike
Message 4 of 11
theonlyandyt
Hmmmm, it's beyond me then I think. The projects are stored in a database, maybe one of the tech gurus has a terminal comand to try. Post your logs.
Message 5 of 11
moreymichael
Thanks.
Cheers, Mike
Message 6 of 11
BKM
It sounds like it's not seeing the media drive those porjects are on. Perhaps in moving to a new location the pathc name for the drive has changed.  Double check the path in OSX and in the Smoke Steup to make sure that the drive is mounted in the same place.
Flame/Smoke Editor
Check out the Premiumbeat Smoke Blog
http://www.premiumbeat.com/blog/category/smoke-2/
Message 7 of 11
moreymichael
in reply to: BKM
Hi BKM
It not only sees the drive, I can create a new job on it. What I can't do is see the existing jobs. I did reboots, restart of Smoke processes, I'm out of ideas.
Cheers, Mike
Message 8 of 11
BKM
Are there folders in /usr/discreet/clip for the missing projects?
Flame/Smoke Editor
Message 9 of 11
moreymichael
in reply to: BKM
Yes.
Cheers, Mike
Message 10 of 11
grant.kay
Would you please go to the start up splice screen and set the project selection from CURRENT VERSION to ALL VERSIONS and see if the projects are visible now?
Many thanks!
Regards
Grant
Message 11 of 11
moreymichael
in reply to: grant.kay
Did that first.
Cheers, Mike
