Hi Guys
I have one question , what about if I need to export something from Smoke with straight alpha so that other softwares can use it without getting that black edge , like a graphics element or a logo from connectFX ?
Divide it first with a logic Op before the CFX output.
Quick question about John Montgomery's pipeline:
the very first Logic Op (for which he uses the Color Correct Node in the end) is used the Substract the Matte from a full white Fill, which results in a negative view of the Matte... So my question is, instead of using a Logic Op, can't i simply use a Negative Node after the Matte, which will give the exact same result?
I'm asking because I don't know if the Logic Op actually does something else than simply creating a Negative view of the Matte in terms of Mathematics?
