when caching .png sequences it happens a lot that some portions of the clip are not beeing cached. Or at least some frames are still pointing to the original .png's so that playback stutters.
This happens both in a normal HD project, but a lot on a current UltraHD 60p project on the proxy-generation (set to 50%).
A workaround is adding an effect, render it and commit the clip. But this is not suitable on the big 60p project.
Observing the percentage counter in the lower left corner gives me the strange suspicion that it is happening to those portions of the clip which are beeing cached during the autosave process.
There are a lot of them. Converting is not an option. Mac and storage are fast enough.
Thanks for any help
Alex
I have actually experienced similar issues. Not sure of the cause 100% but background cache and proxy gens does miss frames from time to time.
Mine are on Qt and P2 so it' snot solely .png related.
Hi guys.
This sounds like a bug. I did not find this issue in our bug database. I'll try to reproduce it and log a defect.
If you still have the app and shell logs from the time of the glitch, I'd love to get them and see what messages the application logged around that time.
Many thanks!
Robert.
thanks for the quick replies.
By the way, caching takes extremely long AND slows down the machine to be practically unusable. (Mac Pro and iMac, tested on both)
In other words: for a background process it creates way too much processing load and for the load it creates it is about 5 times too slow.
There is definitely something wrong.
Alex
Alex
Sadly, that's normal to a degree. I believe that backburner/Wiretap uses 4 cores by default. So depending on what you have left over... things can be quite sluggish.
Yes. Caching to prores does take more time then I would like
