Strange behaviour on Smoke Ext1 SP1: when surfing the media hub now you have to "doble double-click" each folder to see its contents.
Solved by Robert.Adam. Go to Solution.
Same here... Until I double click again, the preview window will keep giving me a "Loading..." message.
Very strange.
Hi guys.
I've tried this on my Mac today and wasn't able to reproduce the issue. The folders would open on normal double-click.
Try creating a new Smoke user and let me know if the problem still occurs.
Robert.
I tried creating a new user but still the same. I attached a movie showing what is going on. Running on a MBP.
Well, looks like I'm getting it now too. I've also tried another Mac running an older OS (10.8.5) and the issue is present there as well.
I have logged a bug (BSPR-13546) and have added your names to it.
Best regards,
Robert.
so maybe we can collect infos, on wich mac hardware/osx version ext1 sp1 is running without the media hub bug?
thanks in advance.
Hi.
I believe this one affects all platforms and OS versions. We have reproduced it on several computers running various OS X versions.
The quick workaround is to click anywhere in the UI or press a key on your keyboard.
Note that the bug only occurs in 2013 Ext1 SP1. 2013 SP3 and Smoke 2015 are not affected.
Mike: we do thorough QA on our software, but it looks that we somehow let this one slip through the cracks.
Best regards,
Robert.
