So, I have an edit with some cut aways(as youy do). The client has now decided that we need to have the sync sound to the cutaways, but I have removed them from tne time for the obvious resasons (the client asked me too).
Now I hit match frame and I get the source clip copied into the library and no sound 😞
OK so I delete the copied clip and try mach content .... same thing. So I try reveal segment ...
i get ..
You'll notice the segment is in the library.
Your clips are sequences.. at least smoke sees them that way. Reveal will only revels to an atomic clip, or one without the filmstrip icon.
How on earth did that happen? These should be regular P2 MXF files. I have done no work on them, simply imported them via the media hub. All of my clips came in this way.
P2 files do that becasue they are not married Video and Audio. They are seperate Audio clips and seperate video clips all tied together with a .xml to make a clip. it's all in the /CONTENTS directoy of the P2 file stucture. That's why P2 is the devil.
Hay Grant,
Thanks for the relpy. My sequence was all edited in Smoke, there was no conform.
So I imported the clips and editied them to my sequence. The weird thing is that now, when I import the clips are correct (eg the are not sequences). I have been unable to re-create importing the clips as sequences. Maybe my import setting were wrong? Is there a button for importing as sequences?
Now I'm thinking about it, I do remember when I originaly imported them, I had a dialog box that I think looked like it was rendering (can't quite remember). My thought was "the devs haven't enabled P2 background rendering yet" It did take a long time I remember that.
weird.
OK so, I think I've figured it out.
In the "Clip Options" - "Format Specific Options" for P2. There is a Clip name setting. By default it is set to "Clip Name from File Name" This causes (my) smoke to import the clips as sequences. I also discovered that if I set it to "Clip Name from Essence" the browser does not update the file names, but when importing the clips I get diffrent file names (persumably from the essence) and the clip is correctly read in as a segment. However, in may case, this switch became stuck. No matter what I set it to, it would consistanly use the "Clip Name from Essence" setting. Only a restart of Smoke resored the function.
This leaves me in a bit of a bind as my sequence has been made with the default "Clip Name from File Name" so relinking may be a problem. 😞
Actually, relinked fine.
