If I use a matchbox or GLSL node (code) and then archive my project/sequence. Will the node persist if I resore the project on a diffrent machine whithout the node installed?
many thanks
Solved by BKM. Go to Solution.
It's my understanding that the Matchbox Effect (node) gets saved with the effect. It's kind of like when you import an FBX, it gets saved (preference) inside the Action effect.
Cool. 🙂
