Solved by jaseo. Go to Solution.
Smoke and Quicktime Player (and other quicktime apps) handle gamma "differently".
QT makes assumptions on the gamma of YUV QT files being 2.2, and RGB QT files are 1.8. Therefore, for a YUV QT such as Prores 422 HQ, it will automatically lower gamma to 1.8 for display purposes.
Smoke does not apply these automatic changes. This means that if you wanted to export a YUV QT from smoke to be used in FCP, you would need to compensate for these automatic changes when you export. (there are 1.8 to 2.2. and 2.2 to 1.8 gamma presets)
It's been an annoyance for some time.
cheers
Jason
