Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Hyper lapse
4 REPLIES 4
mikeparsons
450 Views, 4 Replies
Hyper lapse
Any ideas on an approach for doing this in smoke?
http://youtu.be/SOpwHaQnRSY
All's well that ends. That's why its called finishing.
4 REPLIES 4
A_Over_B
in reply to: mikeparsons
why not just contact the research team at microsoft and see what they have for you.
moreymichael
Mocha Pro might get you in the ballpark.
Cheers, Mike
Late 2013 MacPro, 10.9.5, 2.7 GHz 12-Core, 64GB ram, AMD D700, 1TB SSD
A_Over_B
in reply to: moreymichael
tom_t
Hi Mike,
what you could do is the following (assuming it is not an "endless" scene):
- track the scene in 3D (not perfect necessarily)
- do a 1:1 projection on a card or maybe into a sphere, depending on the movement
- copy the camera and smooth its motion
- use this camera to "film" the projected scene.
the problem is depending on the initial camera movements and your new camera movement you need to zoom in a lot. And you need to do the tracking on the original footage (or not too extremly timewarped)
an idea for getting "more" picture information is using the projections to "paint" the inside of the sphere with the texture by using uv mapping. (that is kind of the basis with what Microsoft does. Well with much more science and knowledge and they are using pointclouds for reprjection and stuff 😉
If you have long and changing scenes it could work by breaking them down to parts and then adding them....
Hope that helps and it is understandable how I meant it.
Tom
