Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
General Discussion
ant-gr
How to delete Lost + Found
37 Views, 3 Replies
07-13-2012 02:05 AM
Hi friends,
does anyone know how to purge all the data in Lost+Found folder ???
It's about 500 GB --lots of space.
thanks
https://vimeo.com/antonisntelis/videos
Please use plain text.
Product Support
Robert.Adam
Re: How to delete Lost + Found
07-13-2012 08:58 AM in reply to: ant-gr
Hi
Do you mean the "Lost+Found" library in a project? That's a library where VIC (the volume integrity check tool) puts all "floating" frames it finds on the storage. I.e. frames that are not referenced by any clip.
You can simply delete those frames.
Take a look at this KB article for additional tips on how to free up framestore space: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15496908&linkID=9242618
If you mean the /lost+found directory on your Linux system drive... that one is used by the file system checker utility to place orphan files it finds on disk (i.e. files that take disk space but are not located in any directory). Normally that directory rarely ever gets such a huge amount of data. That means there was some corruption on your system drive. You can open it in a terminal and delete the files inside, just make sure NOT to delete the actual directory.
Robert.
Autodesk Flame and Smoke Customer Support
If my answer solved your issue, please click "Accept as Solution"
ant-gr
07-13-2012 09:54 AM in reply to: Robert.Adam
Hi Robert and thanks for your response..
I actually mean the library "Lost+Found” and not Linux '
The answer is in the article, thanks a lot friend.
Product Support
Robert.Adam
07-13-2012 10:50 AM in reply to: ant-gr
My pleasure.
Robert.
