Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
How to delete Lost + Found
3 REPLIES 3
ant-gr
369 Views, 3 Replies
Hi friends,
does anyone know how to purge all the data in Lost+Found folder ???
It's about 500 GB --lots of space.
thanks
https://vimeo.com/antonisntelis/videos
3 REPLIES 3
Robert.Adam
in reply to: ant-gr
Hi
Do you mean the "Lost+Found" library in a project? That's a library where VIC (the volume integrity check tool) puts all "floating" frames it finds on the storage. I.e. frames that are not referenced by any clip.
You can simply delete those frames.
Take a look at this KB article for additional tips on how to free up framestore space: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15496908&linkID=9242618
If you mean the /lost+found directory on your Linux system drive... that one is used by the file system checker utility to place orphan files it finds on disk (i.e. files that take disk space but are not located in any directory). Normally that directory rarely ever gets such a huge amount of data. That means there was some corruption on your system drive. You can open it in a terminal and delete the files inside, just make sure NOT to delete the actual directory.
Robert.
Robert Adam
Program Manager
ant-gr
in reply to: Robert.Adam
Hi Robert and thanks for your response..
I actually mean the library "Lost+Found” and not Linux '
The answer is in the article, thanks a lot friend.
Robert.Adam
in reply to: ant-gr
My pleasure.
Robert.
Robert Adam
Program Manager
