Our company has a pretty consistent and repeated workflow, so this is simply for organization/consistency sake, but I would like to create a "default" folder stucture when creating a new Smoke project from scratch, and I haven't been able to find a way to do it.
Ideally, this would be something I could just import, or a script that could be run...
Any ideas??
Thanks!
Solved by Robert.Adam. Go to Solution.
Hi Michael.
One way you could achieve that is to create a new empty project, then create the folder structure you want in it and archive the project (or just the Libraries and folders).
Then each time you create a new project, you open the archived template and drag the libraries & folders from there into the new project.
Does this make sense?
Robert.
Or a very basic way is to create your folders in the OS. Then drag and drop them into your new project.
Thanks for the suggestion!
So after trying this, i discovered that you'll need to nest in a "clip" of some sort (color source or color bars or whatever) in order to drag the folders over....simply just dragging over the Folder Tree Structure I archived would not work on its own.
So there you go! This works great!
