Thanks Grant and Brian.
Brian, I tried re-importing with various Gamma options and the closest in match to the gateway imported clips was the 1.8 to 2.2 option, but still not the same values as via gateway (Importing via 1.8 to 2.2 option resulted in the saturation being a bit high along with high contrast.)
Its good to know that gateway is the most up to date option. But sometimes the legacy import option is a quick way and good way to bring stuff in (with other options like resize etc,). And its not a reassuring feeling to know that you could bring in footage the wrong way by using regular media import option.
A few months ago i worked on a personal project that i spent quite a bit of time color correcting and getting that right look etc, along with other time consuming treatment (DeNoise and stuff). The footage was shot in low light and it looked a little too dark, i couldnt tell and thought thats how it was. The project was 80 to 90 percent done. And now i have to go back and redo and re-match all that stuff knowing that i had quite a bit more latitude in the orig footage than the one i had imported and had to struggle with and that i could have gotten better results by redoing the work with gateway-imported footage.
If the regular media import option is slowly being abandoned and is not up to date that is totally cool. But if its still there in the interface and its good for everything else and not up to date for just one format (a format thats used quite a bit these days) then there should be some sort of indication somewhere pointing that fact out IMHO. Maybe its there in the Read Me and i have simply overlooked it.
Thanks.
2012 SAP2 SP3
10.6.7
Kona 3G driver 10.3.2
Quadro 4000 driver 256.01.00f03
Cuda driver 4.2.10
Mac Pro (mid 2010)
12 Cores / 24 Gigs
CalDigit HD Pro2 (8TB, 723 MB/sec read)
