Just curious. Can it run on a UHD/4K or 2560x1600 30" monitor? or is it stuck at 1920x1200 like flame? Or is Flame2015 supporting a higher res monitor now?
thanks
Solved by fred.warren. Go to Solution.
Nothing has changed with the style of the UI. So Flame Assist will react just like Smoke does on high rez monitors.
As Brian mentioned, Flame Assist's User Interface will adjust to larger monitors just like Smoke does. It does work on the Linux product as well, but we do not support all monitors / resolutions so there's no guarantee from our side.
Flame 2015 now officialy supports the 2560x1440 Eizo CG277 on the Z800 and Z820 platforms.
fred
Does flame 2015 officially support the cg276 as well?
Are teh profiles for the 276 and 277 somewhat interchangeable?
@Anonymous wrote:Does flame 2015 officially support the cg276 as well?
No, the CG276 monitor is not officially supported on Flame 2015.
There's a chance it would work just fine, but it was not certified by our certification team so it is not supported.
fred
Speaking of monitors did anyone see these at NAB? Lots of refresh rates - might make a nice cheaper alternative to the Eizos.
http://provideocoalition.com/atepper/story/hp-revitalizes-dreamcolor-universe-with-2-new-models
