Is it possible? So i do not have to duplicate numerous import, and then have to rewire them all once the input changes? I tried several different nodes with names indicating they could be doing what i want them to do, but i did not find a node that would extract different EXR channel (for example reflection pass) from an image import node.
Solved by Steve_Curley. Go to Solution.
Thanks for quick reply, but this unfortunately does not work. It just creates compound with all the duplicate nodes inside. So if i for example have 20 channels, and i get an updated output, i still have to go through each single node and change the file path.
Yeah, seems like scripting is only possible way in this case. Thanks for your effort 😉
It is just a minor thing though. I am really glad composite is now back in the game as i know how to avoid crashes (having more than one frame in my composition) 🙂
