I notice the export pdf settings by default are set to "current layout". The issue is that the first time I save to export the pdf file it only saves the first Layout even if there are multiple layout tabs and I change the setting to "All Layouts". If I save it a second time with the "All Layouts" chosen, it saves all layouts like it should. It is just a pain having to save everything twice. Is there a way to change the default settings to "All Layouts"?
Thank you in advance,
Paul
