How do I delete all keyframes in text edit? There seems to be a keyframe that I can't see and every time I move a text box, it jumps back to where it was once I play.
You should be able to locate the keyframes by doing this:
1. Go in the Animation menu
2. Select the Filter tab on the right side of the Channels window
3. Select the desired All / Current / Layer display option
4. Enable Animated
5. Select Hide All two buttons below
>>> You should now see only the channels with keyframes on them
fred
You can go in the Animation Menu and select "Reset All Chn" in the blue popup button next to Reset All in the bottom right corner of the Interface.
fred
This is an annoying bug for me because I'm always working in the text editor. It acts like its recording keyframes even though auto key is off. So far my work around has been once I get the text set I go into the animation editor then on the right side by the keyframe controls hit "keep" and "delkey". It's an unnecessary extra step but it works.
Rich
