I deleted a project from the list in order to make room on the media drive. The project is no longer listed, but the media folders still exist on the drive. I need the room, which is why I deleted the project. Never encountered this one before. Any ideas?
Is there another way to get in there and delete the media? (apart from the obvious, dangerous way)
Solved by moreymichael. Go to Solution.
VIC will eventually clear it out.. trya full reboot and launch Smoke and see if that helps.
I did a reboot and a full power cycle. The media is still there. I've got the system off for now. I'll check it later.
Booted up again, and the media is still there.
I've only got one project remaining on that drive, and it's been archived. If I delete that job, then delet the folders inside the ManagedFolder4, is that safe? If I do that, are there any other steps I should take?
Well, I deleted the folders. Seems to be working okay. Started new project.
