Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Deleted Project...did not remove media from drive
5 REPLIES 5
moreymichael
481 Views, 5 Replies
I deleted a project from the list in order to make room on the media drive. The project is no longer listed, but the media folders still exist on the drive. I need the room, which is why I deleted the project. Never encountered this one before. Any ideas?
Is there another way to get in there and delete the media? (apart from the obvious, dangerous way)
Cheers, Mike
Late 2013 MacPro, 10.9.5, 2.7 GHz 12-Core, 64GB ram, AMD D700, 1TB SSD
5 REPLIES 5
BKM
in reply to: moreymichael
VIC will eventually clear it out.. trya full reboot and launch Smoke and see if that helps.
Flame/Smoke Editor
Check out the Premiumbeat Smoke Blog
http://www.premiumbeat.com/blog/category/smoke-2/
moreymichael
in reply to: BKM
I did a reboot and a full power cycle. The media is still there. I've got the system off for now. I'll check it later.
Cheers, Mike
moreymichael
Booted up again, and the media is still there.
Cheers, Mike
moreymichael
I've only got one project remaining on that drive, and it's been archived. If I delete that job, then delet the folders inside the ManagedFolder4, is that safe? If I do that, are there any other steps I should take?
Cheers, Mike
moreymichael
Well, I deleted the folders. Seems to be working okay. Started new project.
Cheers, Mike
