If you have support, call us at the hotline and we'll take care of that for you.
Hotline: (800) 925-6442
Beau
Hi Eduard.
Deleting a project does not directly delete the frame files on your storage.
There's a separate background process that will find that those frame files are no longer referenced by any project and will delete them.
In rare cases, frames are not deleted automatically because of issues. To fix those occurences, you can run the "Volume Integrity Check" (vic) utility in a Terminal:
/usr/discreet/io/bin/vic -a -f
This will find "orphan" frames (frames no longer used) and will set them up for removal. Then the background purge service will delete the actual files off disk.
You can find additional info on VIC in this KB article: http://knowledge.autodesk.com/support/flame-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
regards,
Robert.
Thanks for your help.
For those interested, that allows me to run the vic enter </ usr/discreet/clip/stonefs7> and delete files... rm .ref ref.log ref.rec allow this command to run the vic.
As had already manipulated the pc I had to format the storage and make removSof. (remove all Flame software, reinstall and Done.)
Thank you for your help.
Edaurd b
