Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
DKU-8.0.1 killed Nvidia driver for Z800
10 REPLIES 10
Message 1 of 11
2505 Views, 10 Replies
Installed the new dku that comes with 2014.0.1 and got an Nvidia error on boot.  Here is what dlConfigCheck tells me:
Checking if nVidia kernel module is loaded :          PASSED
Quadro FX 5800 Driver to be 310.32 :                    FAILED 260.19.44
Checking for nvidia 32bit compatibility libs :          PASSED libgl 260.19.44
Hirez certification with video out:                           FAILED Wrong driver!
tried to install from th website and also the .run installer from the DKU (/usr/discreet/DKU/DKU_8.0.1-1/bin/system_rpm/NVIDIA-Linux-x86_64-310.32-custom.run).
/var/log/nvidia-installer.log gives this error:
creation time: Tue Nov 12 10:42:20 2013
installer version: 310.32
PATH: /usr/lib64/qt-3.3/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/lib/modules/dvs/linux/bin/:/usr/discreet/sw/tools:/usr/discreet/sw:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
ERROR: An NVIDIA kernel module 'nvidia' appears to already be loaded in your kernel. This may be because it is in use (for example, by the X server), but may also happen if your kernel was configured without support for module unloading. Please be sure you have exited X before attempting to upgrade your driver. If you have exited X, know that your kernel supports module unloading, and still receive this message, then an error may have occured that has corrupted the NVIDIA kernel module's usage count; the simplest remedy is to reboot your computer.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Tried killing X and reinstalling DKU.  No love.
Looks like it isn't unloading the old driver to allow the new driver to be installed.  Needless to say, Flame opens but once it goes to initialize the video it goes grey and stays there.
10 REPLIES 10
Message 2 of 11
Robert.Adam
Hi
Have you tried rebooting your workstation and then reinstalling the driver?
Robert.
Robert Adam
Program Manager
Message 3 of 11
in reply to: Robert.Adam
Yes.  A few times.  Also, from alternate sources like what I mentioned above.  Nvidia's site and from inside the DKU.
Just did a fresh reboot after installing the DKU and captured this message (attached):
Message 4 of 11
Robert.Adam
Let's try it this way:
1. Reboot.
2. When the blue HP splash screen goes away and you get the "Booting Red Hat Linux.." screen, press any key to stop the boot process. You'll get to the GRUB menu.
3. Select the "Red Hat" line and press e to edit it.
4. Select the kernel line and press e again. this will take you to the end of the line.
5. Add the word 'single' (no quotes) to the end of the line and press Enter. You'll be returned to the OS selection.
6. Press b to boot. This will start Linux in single user text only mode, where the NVIDIA drive is surely not loaded.
7. Run the DKU installer (or the NVIDIA driver installer) again.
Robert.
Robert Adam
Program Manager
Message 5 of 11
I'll give it a try.  I had thought about adding the flag --no-x-check or booting to single user mode.
Good call.  I'll be back in 20 minutes with an update.
Thanks.
Message 6 of 11
Same error message on boot, dlConfigCheck and same issue remains after running DKU from single user mode.
Next suggestion?
Message 7 of 11
Robert.Adam
At this point I advise you to give us a call and open a support case. This sounds like it needs more detailed troubleshooting.
Robert.
Robert Adam
Program Manager
Message 8 of 11
ollieslats
I too I’m trying to update my Nvidia driver
ok when I try the above steps I get three lines
root (hd0,0 )
kernel /vmlinuz-2.6.18-128.e15.ADSK ro root=/dev/VolGroup00/LogVol00 ( arrow thingy)
initrd /initrd-2.6.18-128.e15.ADSK.img
if I Select the kernel line and press e again I get;
<00/LogVol00 selinux=0
I added single at the end of the line and rebooted, I still could not update the Nvidia driver it said that module was already loaded.
Message 9 of 11
ollieslats
in reply to: ollieslats
anyone??
Message 10 of 11
jaseo
If you can't manually install it in init 3, there is most likely a zombie process using the nvidia module that is preventing the upgrade. Monster sparks have been a known culprit. Once you kill those processes in init 3, the nvidia driver update should complete.
Do you have monsters? try running
ps aux | grep -i monster
if that returns any processes, note the <PID> and use
kill -9 <PID>
If that is not it, easiest would be to call support to sort it out in a few minutes.
cheers
Jason
Message 11 of 11
ollieslats
in reply to: jaseo
It was the monsters, followed your steps and got the driver updated.
thanks so much!
