Area :: Header
Maya LT is on Steam
Now with "Send to Dota2" export!
Discussion Groups
General Discussion
New Member
Karhu80
Cropping image sequence in Composite
24 Views, 2 Replies
11-02-2012 02:55 AM
As the title says, how this can be done in Composite?
Crop tool looks good, works fine and then on output, it has no effect!
So is it really that there is no easy way of cropping parts off the image sequence in Composite?
Meaning I have rendered images which I want to crop to minimum, only showing actual character, nothing else. Thats for saving space on final project.
-Karhu
Please use plain text.
Distinguished Contributor
PiXeL_MoNKeY
Re: Cropping image sequence in Composite
11-13-2012 10:54 AM in reply to: Karhu80
Can you please describe exactly what you are looking for and exactly how/where you are cropping the footage? If you could show some images of what you want cropped and screen grab of the current settings you are using.
-Eric
Moderator
Steve_Curley
11-13-2012 12:11 PM in reply to: Karhu80
Deja vu? (sort of)
http://area.autodesk.com/forum/t42144
Max 4.2 through 2014 (SP5/Ext1), Composite 2014.
XP-64 (SP2). i5-3570K @ 4.4GHz, 8Gb Ram, DX9.0c.
nVidia GTX760 (2GB) (Driver 327.23).
