Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Cropping image sequence in Composite
2 REPLIES 2
155 Views, 0 Replies
As the title says, how this can be done in Composite?
Crop tool looks good, works fine and then on output, it has no effect!
So is it really that there is no easy way of cropping parts off the image sequence in Composite?
Meaning I have rendered images which I want to crop to minimum, only showing actual character, nothing else. Thats for saving space on final project.
-Karhu
2 REPLIES 2
PiXeL_MoNKeY
Can you please describe exactly what you are looking for and exactly how/where you are cropping the footage? If you could show some images of what you want cropped and screen grab of the current settings you are using.
-Eric
Steve_Curley
Deja vu? (sort of)
http://area.autodesk.com/forum/t42144
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
