every time I try to import a footage on Mavericks into composition, Composite crashes with following error:
Composite - Fatal Error
MtThreadUNIX: Terminating on unhandled exception:
[Exception Type = N2Dl4PxEx18ExRequestCancelledE, File = internalAPI/procImp/src/pxRequestImp.cpp, Line=4750]
PxRequest cancelled.
from thread:
PxRequestMgr-117
Call stack:Call stack has not been captured.
Anyone knows the solution to this problem? (I'm having this problem since upgrading to Mavericks)
All versions since 2013.
I tried 2013, 2014 Build # 9.0-862715 (which came with Maya) and also Exchange version (Build # 9.0-909216).
All producing exact same error.
I also tried to remove old preferences and let the new version create a new ones, but it still behaves the same 😞
Do you think there is some chance for Composite to be updated so it works with Mavericks?
Has there been ANY solution found to this.
It's so frustrating because I really want to use this software.
The only solution I've found is to get rid of this software, as Autodesk did it already by giving it away for free, with no perspective of future upgrades.
I switched to good old Shake 4.1, which works fine on recent OSX version. I hope it will work also on the upcoming Yosemite. Shake is still great SW... better than Composite.
