Based on what I remember, you are having issues with your caching, I notice in your picture, you have set a tool to catch? Where is this cache being written to. It is important that the cache directory is not stored in the C: drive, this is the past was the default, and probable still is. I have this feeling that you may be having a read write issue. The other most common issue is OpenGL issue, but based on the error it does not seem to be that. Check that out and see if it solves the problem. I have three or four videos on caching and how to set things up. If you are interested check that out.
Cheer
Mark Rasmussen
VFX - Supervisor | Compositor
Enigma|FX
TOXIK/Composite BLOG
http://enigmafx.ca/efxblog
