Hello
Somehow I have managed to lock a clip in batch, it won't allow me to delete the clip or the reel it is in. I have tried to delete it from the batch setup and it still won't let me delete the clip.
Help
C
The only way to delete a clip from the batch setup area in the media panel is to delete the clip from the Batch Schematic.
If that does not work, are you able to clear Batch?
Regards
Grant
Hi Grant
Try to double click in your clip in BXF.
Between "timing Offset" and Override Alpha", you have got something like "clear history", or something like this.
I'm not on the machine...
Click on this and then, you can delete your clip!
Tell me
Hi Guys
Thanks for the advice.
I eventually copied my reels and setups into a new project, leaving the locked clip in an unsaved reel, and then deleted the project. So I can't test the theories.
Thanks for your help.
Charmaine
