Hi Julio.
Give us a call when you have the time and someone will look at the issue.
Robert.
This is the screen shot of the error: Error 123
When you install smoke, it is important that you correctly select the license type that matches your serial. ie. standalone or network.
You will need to uninstall and reinstall smoke to change this. I think you have a network serial, so make sure network is selected when entering serial.
cheers
Jason
Hi Julio.
Also make sure you are using the new 2015 serial and not the previous 2013 serial.
It might be a good idea to log into the Subscription Center and copy the 2015 serial nubmer again, in case there was a glitch in the e-mail for some reason.
Go to your product download page, click 2015 and then click the "Serial Numbers" tab to get the S/N.
Robert.
The upcoming desktop subscription version does not have networking licenses, but the smoke 2015 perpetual version, everything remains the same.
cheers
Jason
Cant Activate Smoke 2015 - Serial Number is correct but just times out ?
On asking for the serial number and product key it says its correct and on clicking activate just times out, seems to connect to autodesk to verify serial ... goes back to same screen ?
Any suggestions ?
I had a similar problem. Here is my thead:
http://forums.autodesk.com/t5/General-Discussion/Asking-for-activation-on-every-launch/td-p/5095960
Robert pointed me to this KB article and it worked.
