Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
Can you add frames in ConnectFX?
3 REPLIES 3
vkshah
690 Views, 3 Replies
I pulled a key in CFX with multiple masks, color fx, and media inputs, but I later realized I needed a few more frames from the head of the shot. I tried to trim and add a few frames in the timeline, but my keying work was not viewable. Does CFX lock in the frames for the clips that are being worked on? Is there a simple way to add the frames without rebuilding the nodes?
VK
Online Editor & Colorist
Flame Assist on Mac 2017
3 REPLIES 3
BKM
in reply to: vkshah
I am guessing that you keys/Gmask are animated?
If you trim out the tail of your clip your effect should still continue on assuming that the clip in questions also has tails in CFX. Check the timmming channels in CFX for clip length. You can also trim out there.
If you key/masks are animaationg then you need to go into the Channel editor and extend those keyframes.
A screenshot might help if this doesn't solve your issue.
Flame/Smoke Editor
Check out the Premiumbeat Smoke Blog
http://www.premiumbeat.com/blog/category/smoke-2/
vkshah
in reply to: BKM
I received a reply from Grant yesterday, but it seems to have been deleted. I did not have any keyframea, but i did have a still image without any handles. Here is what he wrote and what worked for me.
Try this.
Select the last node in your ConnectFX node tree. (not the CFX output node).
Right-click and create CFX clip.
Go into the timing view, and offset the start of the CFX clip. Offset it by however many frames you want extend the front of the clip.
Once you have done that double-click on the CFX clip.
In the Basic menu, explode the clip.
When you do this, it should restore everything as it was before BUT it should keep the offset timing you did as a CFX clip.
That should give you the extra head frames without losing your nodes.
Hope this helps!
Regards
Grant
VK
Grant.Kay
in reply to: vkshah
How bizarre… oh well, thanks for reposting.
Grant Kay
Principal Learning Content Developer
The Official Autodesk Flame Learning Channel
http://www.youtube.com/flamehowtos
The Official Autodesk Smoke Learning Channel
http://www.youtube.com/smokehowtos
Also available as podcasts on iTunes
Follow me on twitter @discreetuk for the latest training updates.
