Forgive me if this obvious, but I’m confused about something.
Solved by Robert.Adam. Go to Solution.
Solved by A_Squared. Go to Solution.
In MediaHub, there is a Projects Tab at the top. If you select the Projects Tab you should see all the projects on your system and be able to move media into your project like that.
Also, there is a convert option when loading the software. On the project selection page, there is a selection box that says something like "Current Projects" or "Current Version". If you change this to "All Versions" then you will see your non-2014 projects. You can then select the project and hit start. You will then be given the option to convert your project or to keep a copy of the old project and create a new one.
Both ways should work.
To further add to Adam's excellent reply: please do not ever manually tamper with the subfolders (1b00, 1b01, etc) in smoke's Media Storage folder (framestore).
Those should only be managed by the application itself. Messing with them could cause the application to lose connection with your project's media cache, renders, proxies and even source clips.
Robert.
