The title basically explains it. When we originally upgraded to '14, we used a temp "scratch" drive for our Autodesk storage. I then added a new media stroage to a large Raided drive connected via fiber. I've done this before and it was added correctly:
[Partition2]
Name=Autodesk_Media_Storage
Path=/Volumes/RAID_002/Autodesk_Media_Storage/ManagedFolder2
Thats a direct copy from "media storage" editor. I have not canceled out the original folder, which lives above and is:
[Partition7]
Name=AutodeskMediaStorage
Path=/Volumes/SCRATCH/Autodesk Media Storage
Thing is, I thought I could have both? When I open Smoke I can switch between both but when I try to create a project using partition2, aka "Autodesk_Media_Storage," I can't. Smoke allows it to be selected but then creating the project is just a dead button.
Do I need to cancel out the other storage, or is this a, dare I say, permissions issue? We've used this Raid before so I'd be shocked.
Josh
Solved by Robert.Adam. Go to Solution.
Hi Grant.
This is the same problem I asked about the other day:
http://forums.autodesk.com/t5/General-Discussion/Can-t-create-project/td-p/5141550
I attached a screen shot of the terminal. It looks like the permissions are the same on the drive that works and the one that doesn't. Not sure what to change, and how.
Hi Josh and Mike.
I've added a reply to Mike's thread with some tips on setting permissions.
I've just tried this on my Mac (Smoke 2015 SP1) and it worked as expected.
Robert.
I apologize. I thought I had said this to email me for a response (and I was patiently waiting) but alas I did not. I've read through this and have gotten it to work. For me it was a permissions issue at the Smoke level. Thank you, as always, for the diligent help.
Mike-I hope you've had the same fortune. Make sure to of course check the folders Smoke creates within the drive and not just the drive's permission rights.
Josh
I haven't solved it yet. I've opened a case, but haven't heard back yet. I have changed every permission I could find, to no avail.
Glad you got yours working, though.
