Hi All
Trying to import photoshop doc but finding that the blend modes are not translating well. The import is genrally overbright, very burnt out, and quite a lot different to the photoshop output. I have tried to simplfy the PS doc as much as possible, such as applying layer masks, turning off smart fx and stuff like that.
Are there any other rules of thumb that could help Flame to read PS doc properly?
Many thanks
Grant
Solved by BKM. Go to Solution.
Also check to see if you're using as ICC profile in Photoshop or not. Sometimes agency supplies artwork with their own ICC profiles attached, or designers supply same. You can edit/work on the file without realising this until too late.
Also, there is a bug in 2013 AE with the Overlay blend mode I think.
