I've been using gestural swipes for this, however, I'm having mixed luck getting the swipes to work. Is there a hotkey for Object Layer Priority I can use instead?
There's a shortcut named "Priority List" listed in the Shortcut Editor. However, that shortcut will not open the same Priority Editor menu as the swipe or the button Grant refered to. It will open the Priority List in the Selected Viewport.
If you want a shortcut for the Priority Editor at the bottom of the screen you could open the Shortcut Editor, click on the Priority button at the botto left of the screen and create a custom shortcut.
fred
