I know that past versions of Flame Premium do not support 24-bit audio when exporting a quicktime, does the latest release?
Thanks!
Solved by ManChicken. Go to Solution.
If you select 'Linear PCM (QT7)' for the codec you can select 24-bit. I'm pretty sure it was in 2014 too.
