Hello, I uploaded a revit 2014 file and I get the error: Translation failed. What may cause this error?
I talked to Swathi today an it sounds like your problem was resolved. We are still digging into it to see what the problem was. But please do post again if you have other issues with Revit files.
Thanks!
Scott Reinemann
Revit Development
Hi Chad,
Can you please give me more information on the upload failure? What OS are you using, and what size is your .rvt file?
Here is a screen capture of the error.
Running on Windows 7.0 + SP1, Chrome browser Version 35.0.1916.153.
The size of the file is 23mb.
I will forward yourself and Kyle a PM of the permalink to the uploaded file.
I do have an even smaller model which did upload and translate.
My initial thoughts are that it looks really good! I have some comments which I will post to another thread.
Same issues as others first upload failed Revit 2015 Model approx. 19MB
W7 Pro x64 SP1 - Chrome 35.01916.xxx - Revit 2015 UR3
Sent a permalink to Swathi by email
Most of the model is missing I only see the roof as shown below...
Thanks to fix this! And happy 4th
I believe I did already but here it is again:
I already invited Swathi but I can invite you as well...
Any luck fixing the issue?
Thanks for taking the time...
We can close the ticket - I found and corrected the issue.
the {3D} view was somehow croped to the roof- I had to detach the Revit model from Central and go back to this view that is only created on a detached file (stand alone).
