fix/unfix -> fix or unfix
In a sketch, there is a two-finger tap / right-click menu option to fix/unfix a curve. This should be replaced with either fix xor unfix so the user knows both the current state and which state they are toggling to.
5 Comments
herzinj
Status changed to: オートデスク今後検討
I agree that we need to do all that we can to make a clear and concise interface. This is a great example of something that can remove some clutter, as well as give users a better understanding of what they are doing to their design. Please keep improvements like this coming!
haughec
There  are a number of toggles that could be made more clear with this improvement (Hide/Show, Normal/Construction, Selectable/Unselectable, etc).  This improvement is also valuable for mixed selections (example: window select 20 objects, some of which are Fixed - Fusion should offer both a Fix and an Unfix option so that results are predictable).
I've logged FUS-13572 to address this.
Charles
haughec
Status changed to: オートデスク審査落選
daryl.wofford
I'd like to add that when you click-hold to see a list of what's under the cursor, there should be lock icons next to the entities that are locked.
emnico7549
Community Visitor
I'd like to add that even though this has been accepted 5 years ago it has still not been implemented.
