Show only
Search instead for
This is an interesting kind of deformation. We are investigating deformation now which may allow us to do this with a lattice deformer but I like the single surface concept.
I believe that deform a complex surface on a more simple as in the example of the photo is a very interesting technique.
For example, having to draw a pair of sports sunglasses, it is easier to draw them on the frontal plane and then deforming on a surface that takes into account the curvature of the front view and side ... I do not know if I explained it well! 😉
Hi I hope the new bending tool can curve things like the attached screen shot. This is a structure I installed on a ring band surface (about 0.35mm tall from the surface of the ring band). This ring is constructed using Fusion 360 with a lot of workflow which included trimming, changing the shape of a plane, etc.. Then moving the final graphical structure to the surface of the ring. If a tool can do this it will be very good to the designers. Designers have to curve things all the time.
